1993 Mercury 25hp 2-stroke outboard leaks gas out of vent hole on integrated carb?
Nealbopper
Hello all. I bought a used Smoker Craft with the merc 25hp 2-stroke. I rebuilt the carb with rebuild kit. No issues, I watched a boat load of rebuild videos. When I was done and had the outboard back together I primed the Ned fuel bulb and gas was shooting out of the integrated fuel pump vent hole. Why is that happening? What should I do to fix that? Thank you in advance. Neal
flyingscott
Fuel pump or Primer? If its the primer replace the diaphragm. If its the pump side make sure you used the correct gaskets.
