1993 Mercury 40hp Classic Water in Bottom Cylinder and Crankcase
ptochman
I have a 1992 Mercury 40hp Classic 2 stroke 4 cylinder that ran great last year. This year it was hard to start. I found water on the spark plug for the bottom cylinder and removed the exhaust cover and found milky water in the crankcase.
How do I determine where the failure is? How do I clean the crankcase?
I will attach pictures. I have not done anything at this point. Your help is appreciated.
I thought I could order a Sierra 18-4325 Powerhead Gasket Kit for starters.
ptochman
Compression is 125-125-120-120
Here are pictures of the exhaust baffle.
Correct there are 2 oil seals on bottom crankshaft bearing housing.---Replace them and perhaps the bottom ball bearing as well.
ptochman
Any tricks to getting the crankshaft end cap off? I got the 3 bolts loose and tapped it with a wooden stick and a hammer but I am leary of hitting it too hard.
Also, no emulsified oil and water around or in the end cap. Still change the seals? The powerhead gasket has what seems to be a lot of carbon buildup and a crack in the gasket by the driveshaft.
ptochman
I found a post by emckelvy to remove the end cap.
How do I clean and protect the inside of the engine?
Thanks for the help guys!
