dukchunter
Thread starter- Joined
- Aug 29, 2012
- 13
Hey guys,
I have a 1993-94 mercury 9.9 2 stroke that has been having issues for a long time. Took it to 2 different Mech. to get it looked at and see why it had a lack of power. For starts, the motor starts first second pull, idles fine without choke.
The mech did tuneups, replaced fuel lines, etc. The one said the exhaust was blocked and a ran a drill bit through it and opened it up.
well none of these things helped much so I tore into it. I tore everything down and cleaned it thoroughly(carb and everything fuel related). I took the exhaust tube out and found that it was blocked at least 80% so I cleaned that all up and reassembled every thing, put it in a barrel and started on second pull, idled fine rev'd up better than ever.
I through it on the boat and headed to the water to test it out. once on the water it ran like brand new, planed the boat out with 2 guys in it which it never did before. after running around with it for about 10 minutes the motor began to surge... eventually got to the point that it wouldnt plane the boat at all. if i would stop and let the motor idle for a few seconds and try to go to WOT again it would go to full throttle then die to almost an idle then surge. i tried running it with the choke on and pumping the primer bulb and neither helped..
It is running on both cylinders and has spark to both, carb has been cleaned thoroughly.
Needless to say i am now stumped... the only thing i can say i saw that may affect anything is a little bit of rust on the lower reeds in the intake.
Any input would be appreciated
