holgo123
Thread starter- Joined
- Jun 12, 2006
- 89
I just finished up a lengthy transom repair... I had everything ready to go... Primed the oil pump, hitched her up and took it to the boat ramp... I backed her in and decided to run it a bit on the trailer. Before I turned the key, I opened up the engine compartment to see if it was dry. Holy crap, water was rushing in... Dissapointed, I drove home. Come to find out that it is the exhaust Y-Pipe not matching up to the replacement transom mount (I pulled the foot and put a hose in the exhaust and water ran straight in to the bilge). I didn't look close enough, but it seems there is a gap along the bottom. The Y-Pipe opening is a little different than the transom mount opening only along the bottom. The bolt holes were the same and it bolted up easily... I used the original Y-Pipe and a transom mount that was supposed to be off a 5.0 L OMC... When I looked up the part numbers on Doug Russell, they are all the same for the transom bracket, and Y-Pipe (even across multiple years...). I am pulling the motor to get to it... The transom bracket that came with the replacement mount has the OMC part # of 986680. I can't find that number listed on Doug Russell... Does anyone have a parts catalog that can cross reference this number? Is there a couple of y-pipes that were used on V-8's? I am wondering if I can find the right Y-Pipe for this mount... My old transom mount is corroded pretty bad and this one is pristine, looks brand new... What's weird is that everything bolted up fine while putting it back together. The only thing different is that a bolt hole was missing on top of the steering arm for a ground strap connection and the pin holding the steering arm to the steering rod was to big big and the hole had to be enlarged a little... I am bummed out a little... When I get it back aprt, I will take a few pictures...
