1993 OMC Cobra Thunking while turning
raquettelaker2
We have a 1993 FourWinns 210 Horizon with an OMC Cobra 5.8l V8 stern drive. Cruising at idle speed is quiet, but when you turn the wheel there is a rapid "thunk thunk thunk thunk" that gets louder the further you turn. The gimbal was replaced last year. Any recommendations? Thanks.
raquettelaker2
Re: 1993 OMC Cobra Thunking while turning
What's involved in replacing u-joints, and do you think the thunking will get worse and cause catastrophic failure, or can the boat be driven for a season like this? Thanks!
dubs283
pull the drive and you will see them between the drive and the splined shaft.
"thunking" will probably get worse then will stop suddenly, then you will be stranded on the lake
fix it now and save yourself a headache and some money too
bruceb58
Honorary Supreme Mariner
You absolutely want to change them now. You either change them now or spend a ton of money on replacing the upper housing of your drive or worse.
