reelbrothers
Thread starter- Joined
- Aug 20, 2016
- 14
Hi All, Bought a Formula 23 with Twin 1993 140's (25 Shaft) first test run it went into SLOW mode , Ive replaced the Vernatherms and springs, didnt want to chance so installed gages on both engines. One engine is running 150 at idle, 112-120 at running. The engine that overheated originally, is running 150-155 at idle and 163 running, removed Therm from the Starboard side, as thats where gage sender is mounted and it fell to 104 (Lowest gage reads) . I replaced all Pump components also. If I understand, its actually a " Pressure relief" more than a therm? Any Ideas what to look for, also how does the cooling system work since each bank has its own thermostat?
Appreciate any input.
