Re: 1993 V6 Evinrude question
When you are standing behind the boat, so that the motor is directly in front of you, the "back" of the engine is closest to you. In the back of the engine are the cylinders. There should be 3 on the right and 3 on the left. Between the cylinders, there should be a metal plate. In the right lower corner, there will be a discharge hose. THIS IS ONLY ON CROSSFLOW MOTORS. For Luper motors, the discharge hose is on top of every cylinder head.
