Just this year the above engine (400 hrs all in salt) developed an intermittent problem as follows - shifting in and out of forward is normal. Shifting into reverse is normal, but sometimes when you try to return to neutral it stays in reverse (at idle speed). You have to shift into forward and then back to neuitral to correct the problem. There is also sometime a telltale gear ticking noise in neutral as if it was very slightly engaging.<br /><br />It sounds like an adjustment more than anything - I have a regular 704 type shifter - or should I look in the engine?
