1993 Yamaha 200 hp txrr carburated. Twin 200's mounted on Mako 261B. Normal rotation motor will not rev to max rpm. Runs almost smoothly thru 4200rpm. Sputters (kinda) and will not reach max rpm usually for that motor 5400. Cleaned carbs and replaced fuel pumps. Ball is firm while trying to reach max rpm. Disassembled and spayed carb cleaner thought out carbs and ran engine at full throttle nice plumes from all six barrells. Pulled manual choke and engine bogged down. Sprayed extra fuel in carbs and that did not help. Fuel flow looked equal and plentiful. New fuel pumps. Compression is good. Swapped CDI units between engines did not help. Electrically checked Ignition coils, stator and pulsor coil all checked to the manual specs. Could they still be bad?
