Fishandboat
Thread starter- Joined
- Aug 11, 2019
- 12
I am putting a tachometer on my 40hp c40plrr Yamaha two cylinder two stroke skiff. Every body was telling me and even online it was a 6 pole. Well the tachometer does not show proper readings on 6 pole but it does appear to look correct at the 2 pole or pulse setting on the back of the tach. It says that I'm spinning my little engine while I'm underway at around 5,800 rpms wide open. It's a stock prop and I'm checking rpms before I buy a new prop. My question is do you think the 2 pole setting on back of tach is correct? I pulled the flywheel and it looks like a simple two pole coil stater. What do you think. I'm going to try and post pics. Thanks
no where online any where referenced this engine as a two pole alternator.
should I try and clean up the corrosion a bit and spray every thing down with corrosion inhibitor?
