1994 200HP high voltage? (16V +), also constant buzzer (temp sensor)
Hubboat
Got my [new to me] outboard running with everything hooked up and ran for a while.
The voltage seems high (16+ volts), is this likely the voltage regulator?
There is also a constant buzzer (engine temp sensor?). Heads are cool, going to change thermostats.
Thanks,
John :cool:
Re: 1994 200HP high voltage? (16V +), also constant buzzer (temp sensor)
Sounds like an accurate diagnosis, I would when you replace the reg/rectifier make sure all connections are free of any debris and are making good contact. Make sure your reg. is properly grounded to a good engine block ground. Make sure all battery/charging connections are good and tight. As far as the buzzer is concerned if it is a solid beep alarm means overheat or no oil (sensor).
