doghunter9
Thread starter- Joined
- Aug 20, 2008
- 101
The motor seemed to idle fine,
surges while at mid and high speed trying to maintain it, but ultimately slows back down. if you bring the throtle back and try to go again it makes the attemp again and fall flat again.
This issue may be related to cold weather operation as I had similar issue all last winter and I though I fixed it the spring by rebuilding the carbs but it may just be because it was spring.
Extremely hard on fuel roughly 7km on a 18ft fibreglass boat for 5 gals,
pumping bulbs helps stop the surging, you could pump the bulb about every 1sec a half a bulb in volume and never get it hard when the motor is running. with the buld full and keeping pressure on it you would have to repump after 3 secs be cause the bulb was fully compressed.
Carbs surfaces have a frost build up on them
any help would be great.
