1994 75 hp yamaha overheating
grinder67
My 1994 75 yamaha is overheating after running at idle for around 2 minutes but doesnt overheat at high rpms after running for more than 5 minutes. The water stream seams to be a little weak at idle but not sure if this is normal or not. I think its a weak water pump but looking for some input from someone who knows more about outboards than me.
jiggin joe
Re: 1994 75 hp yamaha overheating
While you are at it ceck/replace the pressure control valve. The grommet can go bad on them. I am assumiing your motor has one but check parts list to be sure.
grinder67
I dont think the impeller has ever been replaced. But thats where i plan on starting. Thanks for your help.
grinder67
Im not sure what the presure control valve is or where its located but i will check into it. thanks!
While u got the tailpiece off, go with a wire into the watertube and flush it with water afterwards to make sure there is no dirt in it.
icepaq22
had a similar problem with my 95, changed the impellar and the problem went away
grinder67
removed impeller last night was missing the ends off of three of the six fingers! orderd a new one but a little concerned aboat where all the debris from those three fingers whent.
99yam40
And you should be.
hope you will not have problems from them blocking off some cooling passages.
Good idea to pull thermostats and flush everything while lower unit is off.
And make sure the thermostats are functioning properly by testing them
grinder67
I have already checked and made sure the thermostate is working properly can i just run water in the thermostate hole or is there some other way i should flush the engine?
99yam40
Hooking up hose to water pump outlet pipe while lower unit is off and stat is off will allow water to flow and from other way may or may not , but it is the best you can do with out dissembling motor
grinder67
hooked hose to the water pump outlet pipe and with very little presure water started flowing out the pea hole. Does this meen i should be ok and dont have any obstructions?
99yam40
All you can do is hope and keep an eye on things
grinder67
I know there is a considerable amount of rubber missing off those impeller fingers, where else could they have went other than up in water passages where they certainly will cause cooling problems? Also i know im not the first person to have this happen so what are my odds that im gonna have trouble?
grinder67
recieved and installed new impeller friday put boat on the lake saturday and everything worked great! ran boat for several hours no overheating, pump seamed to work better than when i first bought the boat. i wanted to thank everyone for there help! Thanks
