1994 85 hp yamaha overheating
ricwing
Friend has a 94 85hp yamaha,that the overheat alarm goes off when running at a cruising speed or above, he has replaced the thermostat, bolt broke on thermostat housing so headgasket has been replaced to. Has not replaced the water pump yet because the tell tell is strong. at idle or trolling speed it will run without overheating,get on plane in 10 minutes alarm will go off. Compression test reads 110 psi all cyl. Any recommendations.
divinginn
Re: 1994 85 hp yamaha overheating
Replace the impeller and the problem should go away,my yamaha did the same thing.
ricwing
Thank you, that was going to be our next step.
