94Nitro170-TF
Thread starter- Joined
- May 4, 2010
- 8
Hello all,
I have a problem that just started with me yesterday with the 90HP Mariner/Tracker 3cyl. Outboard on my 94 Nitro Bass Boat, on my fishing trip. The motor is oil injected. We launched the boat mid-day, cranked and ran fine, blasted up river a couple miles, no issues at all ran great. We fished for several hours, and decided to run back down river to another spot, well it cranked, idled, planed out and ran fine, just as normal. We slowed down for a no wake zone, took back off fine, planed out and then several hundred yards down the river it started surging, and bogging down. So I reduced the throttle, and stopped, still idled fine, so I took back off, planed out and again on plane at 3/4-WOT it started the surging and bogged down. I stopped again, this time I walked up on the rear deck and kneeled down and checked the bulb on the gas line and it was still firm.
It acts just like it's starving for fuel or running out of fuel when it gets on plane or at WOT. It still planes out fine, it just starts to surge/ bog when it gets on plane/ WOT. So I got it back to the ramp, loaded it up and went home.
Once at home I put the muffs on it, turned on the water and cranked it up. It fired right up and idled normally. With the motor running, I pulled the hood off the motor and checked the fuel lines to see if I seen any leaks and seen none so I Cut the motor off, and pulled the Fuel filter off to make sure it wasn't clogged, it wasn't and I could blow right through it.
Is it normal for these motors to have what looks like black wire ties as clamps on the fuel fitting connections on the engine?
Anyway I noticed that a couple of connection points didn't even have a clamp/tie on them, they were just slid onto the fitting. One was on one side of the Fuel filter. You could see where there had been one but they were gone. So I went to the Auto parts store and installed some regular clamps on the missing ones. Then cranked it back up and it still seemed to run fine at idle.
Could these missing clamps been my problem? Think it could of been sucking air around those points? I haven't had time to put the boat back in the water yet to see if that cured the problem. My Fuel line with the bulb on it looks pretty old, so I believe before I carry it back out I'll replace it as well with a new one.
I was also told to check the vent tube on the tank, so I'll check it before I go back out too.
Anyone have any ideas on what my problem could be? Anything I can check? I just wanted to check as much as I can before I had to carry it to a repair shop.
Thanks for any advice in advance!!
