1994 Bayliner Reflex
johnpaullewis
Bought a 1994 Reflex last year. Added the trim tabs as suggested and they work great (did slow the boat down a bit). I am in the process of replacing the carpet and have already had the seats re upholstered. Thought about it at first, but I wish I had removed the top shell of the boat. It would have made it so much easier to install the carpet, and remove and re install the back seats.
One question if someone could anwser. How do you removed the steering wheel. Its all plastic so I can't use a puller. is it a threaded shaft or does it screw on.
johnpaullewis
Re: 1994 Bayliner Reflex
Already had that off and tried to work it. Put some penatrating oil on last night and will try the wood block and hammer tonight. Plan on paint it and the two side handles to get ride of the rest of the light purple.
johnpaullewis
Reflex Manual--Just got A manual for the 1994 Reflex, email me if you need a copy and I'd be more than happy to share it with you
