kcassells
- Joined
- Oct 16, 2012
- 8,738
One question I have though is regarding embedding the stringers in pb. I keep seeing different methods. Some people are saying to use 1/4" dowels or polystyrene to lift them off the hull. Others pb them down right to the hull. Which method is best and what is the reasoning for the spacers? If I should use spacers, at what spacing do i put them? Any insight is appreciated.
There are alot of ways to do it. Not scientific at all. The concept is to keep stringer/bulkheads from being directly placed on the hull to eliminate " Hard" spots. Hards spots can create stress fractures on the hull which then can run into a lot of issues down the line. Realising the hull is taking a pounding from the water and torque.
Methods include pcs. of 1/8" and larger;
foam, rubbermaterials that if get wet won't promote deterioration. Some shapes are off by 3/4" and still something can be placed under it. Being that high off though can just be filled with pb.
Hope this helps.
As far as materials I went small on the 1st order so I could get a feel for them and progressed in batch orders. I didn't want to pay for leftovers or outdated goods. Of course the way I move bulk wasn't the necessity. Although there may be a price break.
Hope this helps.
