steve in va
Thread starter- Joined
- Jun 20, 2008
- 12
my 94 evinrude 120hp motor is bogging out and nobody can figure out why. i have had the boat for 5 yrs and no problems at all untill now. i was running wide open when the motor just shut down. put it in nuetral started fine, goes into gear and runs fine untill you put a load on it(about 1500rpm or higher) then it runs rough like it's choking out, but if you pull it back in nuetral it clears up. i drained all fuel and changed all filters , added 2 cans of sea foam and 2 bottles of heet to 45 gals of fresh gas took it out and it ran great for 1 hour then shut down again. boat is in shop, now they ran it wide open on dyno and it didn't act up so now they are sending all electronics(stator, power pack etc...) to be tested, it will be a week or so before i get results does anyone have any idea at all? the shop is raping me at 95 per hour and they say they can't fix it unless it is acting up please help steve
