Re: 1994 evinrude 150
60 degree engine right? check the coils for arcing to metal plate that covers the powerpack, sometimes you can see the burnt spot on the plate. Check the coils like OBJ said, all of this ok, do a running test of pack output voltage to coil while comming up on plane, you should check all cylinders.
