1994 Force 120 controls.
kbh121956
This 120hp uses the Mercury style control box. It has a plug that runs the gauges at the helm. My question is, there are five wires. One is brown/blue stripe. Brown/white stripe. Purple. Black, I assume is a ground. Gray is the tachometer wire. What are the brown/blue, brown/white and purple used for?
kbh121956
Ok, I found a little information on the internet. Black is Tachometer ground, Purple is positive on tach, Gray is alt or sender on tachometer. Still wondering what the Brown/white and Brown/blue are used for.
jerryjerry05
Look on the motor for the brown white wire and that will tell what it's hooked to.
kbh121956
Ok guys thanks for the help. Jiggz was right the tan/blue is the overheat alarm. Purple - keyed power to run gauges and stuff. Gray - sender on tachometer. Brown/white - trim gauge. Black - ground. I put this 120HP on a old 1971 StarCraft 18' SS. It had a Merc 140 that was left up for 14 years. It was locked solid, both the engine and gearcase. After replacing the transom and some fresh paint, it will be a great boat for fishing my local lakes.
