kbh121956
- Joined
- Jun 30, 2013
- 497
This 120 really runs well, so well that the ignition switch doesn't turn it off. It uses Mercury's Thunderbolt ignition system. The CDI Electronics website states that the Black/Yellow wire is the kill circuit, if you ground it, it should shut down the engine. Problem is there is not a black/yellow wire on the switch box. Number 11 is the switch box in the wiring diagram, which wire would be the kill circuit when put to ground? Also, the ignition key switch I replaced.
