Hi I am a first time poster but use this forum often to try and educate myself . I bought a 94 1700 capri ls Bayliner with a force 120 outboard back in Oct. So far with the help of my sisters neighbor have replaced the water pump the thermostat both carb gaskets the ignition and fuel filter because it was leaking . I put her in the water for the first time this season last week and when I put the throttle all the way forward pushed in the choke it started easily but I did notice it didn't rev up with in a min or so where I would need to back off into neutral . After a few min s I backed it into neutral and started out of my canal at idle speed actually a little faster then Idle because it seemed it was going to stall. I noticed the motor would jerk is the best way I can describe it but no bang or noise at all that I could hear, when I got out to the intercoastal I gave it a little more gas and still noticed the jerking not constant maybe every few min s. so I went to full speed and still felt the jerking but more frequently . I have done some reading and it seems it could be the shift cable or a slipping hub " but I didn't hear any rev " or a worn clutch dog and forward gear . I really hope its not the latter ... when I was letting it run while lid was off I did notice some gas dripping from bottom carb even though gaskets were replaced last oct. . and when I was running boat I did prime the bulb and it didn't make a difference in jerking. I cant do any work on my own YET : ) but just hope to be as informed as possible before taking boat to a mechanic I barely know . Sisters Neighbor not available : ( One last thing I did notice some slight stress to transform the top molding had a crack in it but could be normal wear .
Thanks ! any info would be great !!
Lady in distress ; )
