1994 force 120hp
abbotm5
Im trying to find a replacement for my 90hp force outboard that is on my 1991 bayliner 1800 capri. The motor pictured in the attachment is a 1994 force 120hp outboard. I wanted to see if anyone had this motor or knew some details about it. Mainly, I want to see if it will mount to my boat and if it is a decent motor.
CharlieB
Re: 1994 force 120hp
Only problem I anticipate is the 120 may be greater than the data plate on your boat allows.
Look to be sure, if your hull is rated for a 120 then bolt it on!
roscoe
It is no better or worse than you 90 hp.
It will mount on your boat, but is your boat rated for 120 hp?
abbotm5
The boat is rated up to 120hp. Thanks for the help.
