gopedgsr40kid221
Thread starter- Joined
- May 19, 2009
- 22
I have a Honda outboard. Con-troll box has starting to beep. The lights for the temp. and oil warning wasn't on so i turned off the motor and put the ignition in the on position and shifted forward and it started to beep AND THE MOTOR wasn't running.When its in neutral it dosent beep but when you shift it forward about half throttle it will beep same when i put it in reverse and when i am doing this the motor isent running at all.. What can be the problem?
