1994 J150 upper motor mounts
jwellcraft
Anyone know any special way to remove the old upper motor mounts on these motors when they are stuck? I had to use a drill with a big bit to ream out the retainer because that wouldn't move either.
jwellcraft
Re: 1994 J150 upper motor mounts
Sorry, should have explained more but the bolts have come out with no problem, it's the mounts itself that will not move.
Fl_Richard
Your machine shop can pull them super easy. If there in like mine were you'll just bust whatever your prying on to remove them.
If your having the blocks done let them pull them. They had a tool they had made to remove them. They look like they had threaded the mounts and pulled them. My shop also had "used" mounts that were indistinguishable from factory fresh at a substantial price savings.
BTW my engines are 1995 150's so I know exactly where your coming from.
jwellcraft
Yes thanks, I think I might need the machine shop to pull them because these are in there good.
Fl_Richard
You will not get themout yourself. If you do your superman :)
jwellcraft
I kind of think I am sometimes..:D
jwellcraft
Guess what guys, I got these out using a ball peen hammer (piece of cake) just aim straight.
