Softball60
Thread starter- Joined
- Jan 9, 2023
- 16
The last time I posted a thread was back a month or two.
I purchased a 1990 sport craft w/ a 1994 Johnson that I was going to reduce for my grandson……So much for background!!
I have completed the compression check and looks reasonable considering the engine has sat for over a year.…all four (4) cyl s. We’re between 95 and 105. Hoping with some time rings will reset a little and compression may go up?
Before I explain my question I need to explain that I left the manual release for the tilt trim open for quite a whiIe after I failed to manually raise the motor.….I am 77 yrs. And my strength was not up to the task.
Now that the electrical is done I tried to raise the tilt/trim…..MOTOR RUNS BUT NOTHING MOVES!!!!!!!!!!!!
IS IT BECAUSE I HAVE AIR IN THE HYDRAULIC TILT/TRIM?
THANKS
SOFTBALL60
THANKS
SOFTBALL60
