1994 Johnson 150 Fast Strike No Oil alarms working
motoman
I had a issue with the Oil Inject pump leaking. Replaced the VRO and followed BRP recommendations on starting up on a different tank with mixed fuel and the oil line disconnected I should have got a no oil alarm but didn't . Where should I look to see where to correct this? My concern is that no other alarms will work also such as overheating ,low oil .
Chris1956
Honorary Supreme Mariner
An OEM service manual will tell you exactly how to test the OMS pump and alarms.
You should get a no oil alarm several minutes after the oil line is disconnected. It is recommended you run the motor at 1500 RPM (on mixed fuel), during the test.
