z.fields27
Thread starter- Joined
- Dec 3, 2023
- 33
About 3 months ago I got a '94 Stratos with a Johnson 150 and the engine was running perfect. A few weeks ago however I went on a fishing trip and the motor had some issues. I was idling along when an alarm sounded. My first thought was to make sure it was still peeing (which it was) then I thought to make sure I hadn't run out of oil. When I stood up smoke was pouring from the vent on the cowling. As soon as I realized that I shut the engine off and took the cowling off. As bad as the engine was smoking I was sure something was on fire. I then used my fire extinguisher just to realize it was doing nothing. Soon I realized it was some kind of electrical part burning up. I disconnected the battery and slowly the smoking died off. When I finally got home I discovered that my voltage regulator had burnt up. By the looks of things I assumed I could just get a new one put it in and be fine. However, once I installed the new one there were some issues. The motor had no spark. After investigating and trying things the only way to get it to run is to spray contact cleaner on the optical sensor. Once applied the engine will then start. I got the sensor out and it appears that it is fogged up somewhat and when sprayed with the cleaner it clears up. Once running it will only run for so long before revving up and then shutting off. That is where things become interesting too because my girlfriend said that just before I turned the motor off when it was smoking that it revved up like it is doing now. Sorry for the long post, I just assumed these details would all be very helpful if anyone has any possible ideas as to what has happened?
