jwellcraft
Thread starter- Joined
- Nov 5, 2009
- 233
Just completed a full rebuild of this motor and the first trip out all went great and got 2.5hrs but then on my second trip today all was going great until the ending part of the trip. As I was heading back to the dock the warning horn srarted doing a constant beep but those very rapid ones not like the regular low oil, no oil, overheat or fuel starvation alarms and the tach was jumping with the beeps and went up and down and even dropped to 0 sometimes but would catch back up for a while then start again. The horn even did this with the motor off but key in on position (bad horn maybe)? Anyway continued back and running around 3,000 rpms the motor quit but not like the seize type of stop, it just got lower and lower before it shut out and wouldn't re-start. It was getting fuel but I didn't check the spark on the water so I got towed in. I got home and tried it again and nothing just rolling and rolling. I disconnected the black and yellow wires up by the voltage regulator and the power pack just to see and tried it and it fired up but the horn was still doing those rapid beeps and tach wasn't registering. Then noticed the stator wire harness looked a bit chaffed and old and was touching the block so I lifted them up a bit and it ran fine for a while with no stalling then starting stalling after a few seconds again. Could these stator wires touching the block or breaking down cause these problems I have experienced?
