1994 johnson 50/35 jet no spark
JoshKeller84
no spark on either cylinder - here is what i tested so far.
removed killswitch wire with no gain in spark.
brown and brown/yellow wire together produced 155 - 160volts.
orange and orange black wires - powerpack hooked up 5.5v. powerpack unhooked and meter hooked up to stator plug - 80v (big difference)
from the powerpack to coil plugs -
orange/blue to blue was 126 ohms
orange/green to green was 5.7 ohms. (big difference)
these test following the cdi guide lead me to believe the powerpack is the problem. Any thoughts or comments? thanks
boobie
Re: 1994 johnson 50/35 jet no spark
What kind of a meter are you using ??
JoshKeller84
standard multimeter... figured that was the "dva non connected" ranges. basically just took the highest consistant number i got over a period of 5 seconds or so.
