Re: 1994 Johnson V4 90HP with idle & charging system problems
I went out and purchased a rectifier & 2 carb overhaul kits.<br /><br />Upon installation of the rectifier, I noticed that there was nothing like what I bought (the rectifier) installed on the engine. <br /><br />This rectifier has 3 wires coming out of it: red, yellow, yellow/gray.<br /><br />I can see the voltage regulator unit bolted onto the block, located underneath the flywheel. This unit has 5 wires: yellow, yellow/gray, gray, purple, and red.<br /><br />All the wires go into a junction strip on the side of the block.<br /><br />Seeing that the wires from the rectifier match up to the wires of the regulator, does this mean that the voltage regulator already has a built in rectifier? Meaning, it is a rectifier/regulator assembly?<br /><br />So from what I can see, there is no rectifier installed.<br /><br />I noticed that there is a place for it right next to the junction strip. Does this mean that I should install it and wire it up parallel to the wires coming out of the regulator? <br /><br />Well, I install it anyways. I wire it parallel (according to wire color) onto the junction strip.<br /><br />Boat started, still no idle and no charging system.<br /><br />There are two wires, yellow and yellow/gray that come out from beneath the flywheel. I'm guessing these are the stator wires. Anyone know the Ohm spec? <br /><br />I checked the resistance between these two wires; I think it was about 3ohms. Sound right? Checked each wire to ground to make sure they weren't grounded, it was OK.<br /><br />If anyone has any other advice, it'll be greatly appreciated. I'm still waiting for my Seloc manual, hopefully it'll arrive tomorrow. The manual would probably answer most of my questions. <br /><br />I haven't "monkeyed" with the carbs yet; I'll wait for manual before removing/cleaning the carbs. I would like to get the charging system figured out first. <br /><br />Again, thanks to those that have helped.
