1994 Lowe Silhouette 19' deck boat
bass or bass ?
I recently purchased a 1994 Lowe Silhouette 19' deck boat and it rides beautifully compared to my old Glastron Sportster tri-hull. The Silhouette is a modified V hull like a bass boat. It outperforms my old boat in every way and I couldn't be happier!
Here's the old 1977 Glastron Sportster tri-hull.
I've been unable to find out the fuel tank capacity for my 1994 Lowe Silhouette deck boat. Any one have that information? :confused:
Watermann
Re: 1994 Lowe Silhouette 19' deck boat
Look for a hatch, probably a pry out hatch, it should be under one of them. When you find it there should be a tank placard visible with the info.
bass or bass ?
Thanks. There is an access port to the float and hose connections. I'll check there.
riknkeri
i just bought a 1994 lowe Silhouette 1900 deck boat with a 120 evenrude, i was wondering if u still had yours and if it has a 120 hp evinrude motor. if that is your set up im wanting to know how fast yours will go.mine with full tank of gas and only me in it goes bout 31 mph....i guess i was just expecting a little more speed with a 120 hp.....thanks prop 14x17....4700rpm
bass or bass ?
My boat has a 70 hp Johnson and with the motor trimmed down @ 75% will run that fast with 2 people, and a full load of fishing and camping gear.
