Harritwo
Thread starter- Joined
- Oct 4, 2011
- 586
I purchased this boat about 6 years ago with less than 100 hours total time on it. Currently it has 210 hours total time, 20 hours since overhaul of the outdrive/transmission due to gimble bearing failure and water intrusion in the transmission. This engine will start with in two revolutions of the starter on a cold start. It has a merc carb and has been rebuilt. When it is hot, after running like skiing, tubing, etc... to restart the engine you have to advance the throttle to the half position and continue advancing to WOT while cranking. WHen it restarts, you immediately return to idle and the engine runs fine. The fuel system has been checked, all new fuel filters, no water, Carb rebuilt twice. The electric choke has been unhooked, and wired open. I think it might be a vapor lock condition but have been told by my local marine mech that on these engines a hard hot start is characteristic.
Is that info correct? What can be done to help it? The fuel lines are original and are not toucking anything. THe line from the pump to the crb sits about an inch off the moter running up the side, across the valve cover and into the carb.
Thanks for your help.
George
George
