1994 mercury 25hp 2 stroke
Tom29274929
I have a 1994 mercury 25 and disassemble it and don’t know how to get the flywheel/timing off
Use a puller with 3 bolts to get the flywheel off.----Lots of videos on U-tubeI think.
Faztbullet
Be careful as that's a Mercosil engine block. Have to use special type tools to repair cylinders if damaged
flyingscott
Did you take the washer off? You take the bolt out remove the washer and put the bolt back in tight.
