1994 mercury 40hp won't idle
robert53a
Hi I have a mercury 4cylinder 1994 model 40 hp that is hard to start and will only idle when the key is constantly puch(squirt of gas from enrichment valve) I' thinking it time to re-build the carbs. The engine ran fine all last year but was getting harder and harder to start. I just want to see if you guys think the same or am I barking up a wrong tree? I value you guys' opinion. Thanks.....Robert
Laddies
Banned
Re: 1994 mercury 40hp won't idle
While cleaning the carbs put a kit in the fuel pump also, what will update the engine to E10 fuel.
robert53a
Thanks for the advice I'll do that.........Robert
robert53a
Hi what is a good brand of carburator cleaner and technique to use to clean these carbs? Thanks..........Robert
Laddies
Banned
With the carbs disassembled any brand of spray carb cleaner will work, be sure there is good flow by spraying through each passage with it.
Robs88
You should check your reeds while your in there also.
