1994 OMC 5.0 Carb No spark
suds1421
Good morning everyone,
I have a 1994 Four Winns Horizon 180. I had it running about a week ago for the first time this year (kids sports delay the season for us). Put it in the water yesterday and wouldn't start. Would turn over but wouldn't start.
Took the cover off, definitely has gas going to/through the carb.
Pulled a plug, grounded and checked for spark and didn't get any spark. There's power to both sides of the coil and there's power coming out of the coil to the distributor. The rotor was replaced last year and it is rotating.
Any suggestions of how to diagnose further?
Thank you so much for any help you can provide.
Do you have spark at the coil ?
suds1421
A couple questions:
1) Does anyone have a source for the ignition module?
2) Does anyone have a source for the distributor assembly?
I'm thinking about replacing the distributor for piece of mind if I can find one.
If you have spark at coil, and not at the plugs, your issue is the cap, rotor or wires
However if you want a new dizzy, look at the delco voyager
suds1421
Update after double checking (i didn't check the spark, buddy did) we don't have spark off of main coil wire.
suds1421
No spark from coil
I have a 1994 OMC 5.0 with carb. After running great after summerization it now won't start. There is definitely gas getting to the carb, we can smell/see it.
There is no spark when pulling the large wire from the coil to the distributor and placing a ground very close to the end of the wire.
The voltage on the positive side of the coil measures at 11.0v and measures at 2.4 volts on the negative side when the key is on.
GA_Boater
Please keep this no spark issue in one thread or you be asked the same questions repeatedly.
SpitAndDirt
You stated you had power to both sides of the coil, but have you removed the coil to check the primary and secondary winding resistance? According to my 1992 manual for the Carb 5.0, the primary winding is supposed to be 1.43 ohms to 1.58 ohms. The secondary is 7.5 to 8.7Kohms. If you are unsure of how to perform this check, google and youtube are your friend, like always. :)
As for the distributor, no replacement is required unless you know by visual inspection that the shaft of the distributor is bent or if the drive gear is sheared. In most cases, I distributor is replaced only if the components aren't sold separately but as a complete assembly i.e. certain Honda distributors from the early 90's.
It could be possible that your ESA (Electronic Shift Assist) module could be malfunctioning which in this case, you could just unplug it and try to start the engine. The ESA is responsible for dropping out ignition pulses for the specific purpose of allowing the gears to mesh easier. If your linkages are set properly, the ESA only works for an instant as the Power Lever is moved from Neutral to Drive. It's also possible that your tachometer could be malfunctioning and grounding out. Try disconnecting the tach signal wire to eliminate that possibility. The idea is to simplify the problem to the most basic components and see what happens.
Depending on the condition of your engine, you have electrical components that are over 24 years old. The distributor is the last item I would suspect since it's basically a spinning shaft held in place with bronze bushings.
If you suspect the ignition pickup, you can buy a new aftermarket replacement. A couple years ago, they didn't have these available. Your factory ignition pickup part number is 987194. Pertronix has been manufacturing point replacement setups for years. I have installed 3 of them over the years on different vehicles and they work great.
https://www.amazon.com/Pertronix-1589-Prestolite-Cylinder-Ignitor/dp/B004OXPDC4
Hopefully some of this info will guide you to a solution. Good luck!
suds1421
I will check the coil in the morning for resistance.
Where would the ESA be to unplug?
Thanks!!!
suds1421
Coil resistance was within the specs above. Boat has new coil, cap and rotor.
Where would the ESA and tach wire be to unplug them? (I understand only a troubleshooting method)
Horigan
You may not have an ESA module. Being a '94 this is likely a Volvo/OMC joint venture engine/drive and I don't believe they have an ESA. At least my '95 doesn't.
If you don't have an OMC manual, there are good troubleshooting tips in the link below.
