jimmbo
- Joined
- May 24, 2004
- 13,652
Check to see if the timing is correct and that the advance mechanism if working. Also check to make sure the carb is opening fully, and that the choke is fully open. The edelbrock should help even with the 2bbl as the small ford does have a choked up induction system. You might want to restrict the heat crossover passage a bit, as the aluminium will transfer more heat to the runners than the cast iron manifold did
