1994 sea rayder engine change
Markiecochran
I have owned a f14 sea raider for many years. it would stall after being in the water for an hour or so then would have to cool to restart. I ordered a used stator for it...….10 years later....used stator on shelf still uninstalled I decided to get her back in the water since I just moved to a waterfront canal home.
I attempted to remove the fly wheel.....which resulted in my beating the magnets off the flywheel !!!...bigger hammer theory did not apply to this job.
after knowing the history of these engines....even though I have a matching spare parts boats....I decided against trying to remove the flywheel from it thinking I might come up with the same end result....broken magnets.
to trusty craigslist I go and find a running 1990 85hp force outboard with a broken lower unit for $100....which I bought. I now have the 85hp separated and sitting awaiting to become a donor. it is different in a few ways....mounting bolt pattern for start...but according to the fellow I bought it from...who was a boat mechanic....the crankshaft splines will match the l drive shaft ??? (that's a do you know that as well question)….I haven't gotten that far yet but both are 15 spline. I can make a thin adaptor plate to bolt to 85's base and then mount it to my l drive...if the splines match....hope to know that answer in the near future.
next...and another question hoping you might assist with....the exhaust on the 85 vents out the outboard lower unit. on the 90 sport jet the exhaust manifold has a built in elbow and fitting that turns it out to a bellow....do you know if the 90 manifold would bolt up to the 85 head? another thing I hope to find out in the not so distance future !...but hoping you might have input.
I saw where I fellow put a 350 v8 in one of these boats....I support foolishness totally....but am only attempting to modify my boat very little....and at the same time maybe open up the engine swap possibilities for other owners of these cool little boats...it holds a dear spot to me for the protect the manatee no prop feature. seems the thought is that nothing will bolt up so changing to anything else is not possible. I hope to be able to open a window into a different idea....in that if you can match the splines....then it can be made to adapt. I have done car mods and am somewhat knowledgeable in turning a wrench....but I always like to listen and learn for a guy that knows....hoping that's you....or maybe someone else has attempted this....I don't see anything on the internet bout it though.
thanks greatly in advance for any help or advice you might send my way...….
GA_Boater
Welcome aboard.
Did the manual say to beat the flywheel off? :doh:
Can't help with the other questions.
Not a Mercruiser or even close. Moving this to the correct section.
Brien S
Welcome aboard.
Actually, doing a little research, it looks to be a mercury outboard/jet drive. Called a Mercury sport jet.
To the op, they make pullers to get the flywheel off. Seeing a picture of the flywheel, it looks like a harmonic balancer puller might work.
You will find that it is a -----FORCE outboard motor block.------Yes they are marketed as a Mercury Sportjet.-----
QBhoy
Maybe I’m reading this wrong. It’s late here, haha. Is it that you want to put a outboard donor motor in a jet ski or a jet boat like the ones that have the sport jet in it ?
if it’s in a jet ski, your first issue will be that I think the original engine in that ski (if it’s the one I’m thinking of) revs out to around 7000 rpm and the prop is direct drive and suited to that. The force won’t do that...or if it does. It won’t last long.
Apologies if I have it wrong.
