1994 seadoo gtx
leroy48335
I have a 1994 seadoo gtx that blows a 15 amp fuse the instant i push the start button.
The engine will crank over but there is no spark at the plugs . I'm not real good with electronics .
does anyone have a solution.
No expert but with it blowing the fuse, my guess is the ECM is the issue or coil, Could put a 20 amp fuse in and see if it will run. If it does then don't leave the fuse in. Something has just started drawing to much current. Use a ohm meter and check the coils to see if they are close to the same
Had a 95 with a control module, in parts book its called electronic module assy
vroom ZOOM
I stand corrected... seems like its a cdi box with a little more authority...
