Rranger
Thread starter- Joined
- May 18, 2009
- 479
I took this boat out for the first time today and was using the bilge pump to pump out a sizeable amount of water and drained a good amount out the drain plug after getting the boat out of the water. At the back is the bilge hole which I had a plug in and another hole to the right of it facing from the rear. The plug hole on the left the drain plug hole was not attached to any hose on the other side transom. The hole on the right you could feel a pipe or tube attached to the plug hole on the inside of the transom. So I’m assuming that is the pipe going to the livewell for caught fish. I’m guessing that pipe going to the Livewell at the front has been compromised somewhere in between the transom and the livewell at the front of the boat, likely from some frost damage. I was thinking I could rig up some low pressure air off my compressor and plug the Livewell inlet and pump some air from the back to see if it pressures up or it doesn’t . That should answer the possible leak question. It’s not a case of just looking because of a solid wood floor that only comes off with a ton of work. Anyone got a better way to check out the potential problem, or should I just open the drain start filling the holding tank from up top with the drain open and see if the water comes out of both the drain hole at the transom and the livewell fill hole at the transom? Never had a boat with the live well before.
