1994 V4 115 Johnson Bubble back fuel consupmtion
Fishjustin87
I have a 94 115 bibbleback that I converted to a conventional diaphragm fuel pump. I bypassed the VRO. Through this forum I was told to se a 1983 140 fuel pump. Works great and runs strong. It shutters a little in gear at low RPM but seems to idle and run great at WOT. What is normal fuel consumption for a motor like this. I seem to be burning about 6 gallons an hour between Wot and putting around pulling pots. Is this normal or do I need to lean out the carbs a bit? If so what would be recommended? Both carbs have 2 screws on the face of them. Cant really use the manual for this as I converted away from the Vro. Any input would be much appreciated. Thanks
Removing the VRO would make no difference as far as following the manual !-----I do not see any mixture adjusting screws on these carburetors.------But post a picture of what you think are adjusting screws.
Bosunsmate
If you run at WOT you will use a lot more fuel than if you ran at about 2/3 to 3/4 throttle.
Fishjustin87
Racerone, I believe what I was mistaken is an idle orifice. ORIFICE, IDLE, #38C. #7 on the carb illustrated parts catalog. Looks like one on both carbs. What are their function?
flyingscott
They are low speed air orifices they affect the low speed air/fuel mix. Those motors are just thirsty beasts they always were and will be. 6 gallons per hr is not bad the rule of thumb is at WOT you will burn around 11.5 gallons pr hr.
jimmbo
o
without knowing which/whose parts catalog you are referring to...
on a carb, an Orifice is used to restrict either fuel flow, or as an calibrated air-bleed, both of which are used to calibrate the carbs fuel delivery curve
havoc_squad
If iBoats carries what you are asking to buy/get, it is against forum rules to list competitor names in forum posts/topics.
That is why your posts are being edited by the admins.
If in doubt, PM an Admin.
Fishjustin87
This is not to purchase. Only for reference so he knows what screws I am talking about. Pretty sure diagram referenced is the omc one
