Re: 1994 volvo penta 250 seems to slip out of gear upon throttle up
Spare prop worked just fine! Must be the original prop. New problem, or at least the other problem resurfacing. I get up to about 4000 rpm or at times just by accelerating too fast, a major vibration happens that makes me immediately pull throttle back to idle. Most of the time, the vibration goes away and I can again accelerate to 3900 rpm or so. If I dont go over that rpm, engine will keep running just fine. It does kind of go in out of smooth operation to slight vibration at all times though at upper speeds. I would also like to mention that there are times when even coming all the way back to idle position, and even putting boat in neutral, the harsh vibration does not go away and I actually have to turn motor off and restart. I am assuming therefore, this has nothing to do with a prop. Any ideas? Thank you all so much for your help earlier. It is much appreciated. I would also like to know if someone can tell me, what are the bearings for underneath the top of my outdrive around the dip stick area? I took off this cover and noticed that there are quite a few flat spots on these bearings. Are they supposed to be that way?
