wes tanner
- Joined
- Oct 27, 2003
- 7
I am rebuilding a 1995 115 evinrude bored 40 over.I got some questions.My manual say you have to use a special rod cap alignment tool part number 396749.Where can i get this tool or is there way to align them without?My other question is about the needle bearings i kept the bearings with each rod and piston so they go back in same place on crank.I used a micrometer to check crank its in good shape but i dropped the bearings and now im wondering are they wore a certain way and have to go back exactly the way they were or does it matter?Should i get new bearing for the rods?What do i use to put case back to gether rtv or do they have a special sealent? Any one ever used vertec pistons they are made in italy.Im wondering if the ring end gap is the same as book?The directions that came with pistons are in italian.My machine shop said they new what to bore it to.i just want to make sure every things right dont want to grenade a new motor.Thanks WesTanner
