tater76
Thread starter- Joined
- May 7, 2010
- 712
Hey folks, so I screwed up after hurrying though an impeller change on a 95 120 Force. I forgot to put the shifter in forward before pulling the lower :facepalm: My brain tells me that to reinstall, I just need to shift the handle into forward, then turn the shift coupler on the lower until forward gear is engaged, then gently reinstall the lower making sure the coupler and rod splines line up right? Well.... I must be missing something because it just refuses to be set correctly. Oh, this is the Merc style lower unit if that helps. Any tips would be greatly appreciated as the manual is kind of bleak on correcting stupid mistakes.
