boater1234
Thread starter- Joined
- Jan 6, 2010
- 869
I just bought a really nice clean 1995 15hp 2stroke merc,besides checking to see if it has great running water out of the pee hole and making sure the thermostat is opening up properly is there any other maintenance i need to do to it?I am changing the plugs,i just changed the fuel filter under the cowl as well as all the fuel hoses and coolant hose to the pee hole,if everything seems to work good i figured i am going to run some really good stabilizer through the gas called k100 as well as ring free from yamaha and i am going to run the engine a bit richer the first tank because i don't know how long it's been since it's been run and i want to re lube all the internal parts with just a bit extra oil then go to the 50:1 oil ratio,i'm also using 100% synthetic tcw3 oil.I want to keep the fuel system as clean as possible with a new tank and line.
If i'm doing something wrong or i need to add anything to this please chime in,thanks.I don't know how many parts are original or have been replaced but it is really a clean motor and i'm going to start it soon here.The compression is a dead even 120 on both cylinders so i know that's ok.
Just a curious question:would it make sense to use one tank of ethanol fuel because i know it's a natural cleaner and would clean the entire system if there was any minor issues,from what i have been told it runs really good and idles smooth but i will find out later today or tom.I normally use ethanol free fuel but i have no idea what's been used in this outboard.
