1995 25 HP 2 stroke Johnson
Coednaked
I just bought a used set up - a welded aluminum boat with a 25 HP 2 stroke Johnson outboard. Previous owner said he bought the engine used about 4 years ago and it had reasonably low hours on it when he bought it, and he's put 20-30 hours on it per year since. He says the engine has been extremely reliable in the time he has owned it. After talking to him a while and considering he also posts on a fishing discussion site I also post on local to myself, I feel I have reason to trust him. I just started the motor today and she seems to run good. Reasonably quiet for a 2 stroke and idles well.
Anyways, a few questions:
1) Previous owner said he removed the oil injection system and has just been pre-mixing it and it's worked fine that way ever since he did it. I didn't ask him what he has been pre-mixing it at but the gas he left in the tank definately has oil in it so I'm gonna huck a guess out there that it's probably 50:1 - any ideas (also going to call him to ask)? I am going to run Amsoil HP Injector 2 stroke oil which is safe for pre-mix or oil injection applications and it meets TC-W3.
2) I'm going to change the leg oil but I can't find any spec's about the leg oil in the owners manual I have. I was hoping to switch to Amsoil Marine Synthetic Gear lube which works for 75w90 or 80w90 applications (I'm a big fan of synthetics by the way).
3) Any known issues or points about the particular engine I have?
Thanks.
HighTrim
Re: 1995 25 HP 2 stroke Johnson
Welcome to iboats.
There is nothing wrong with premixing, and yes, it will be 50:1 regular 87 octane fuel to TCW3 oil.
The recommended lu oil is 80-90 outboard gear oil, it has additives to protect the lower if you have water intrusion. Always replace the washer on the vent and drain screw when doing this.
jbjennings
I'm just curious, but I own a '99 30hp johnson which I bought new and it never had oil injection. You said he disabled the oiler and started premixing? I'm suprised it ever had that on it!
And the alwelded boats are great!
JBJ
Coednaked
That's what he told me plus the place where the oil injection tank is, is missing. I know he said he still had it - but I never divulged too much into why he got rid of it, etc. Plus, pre-mixing is easy.
HighTrim
Might be a good idea to get it off him anyways. Good to have.
