1995 25hp johnson please help
00powerstrokin
when i head out across the lake my tach stops working? some times it works at idle. i figure it is just a loose connection on the motor and is stopping from vibration. where is the tach wire connected. i already checked the back of the tach and everything seems to be in order there.
OBJ
Re: 1995 25hp johnson please help
Welcome 00powerstrokin!
Go back to the engine on the starboard side and look for a small can on a triangular base. This is the rectifier. Should have three yellow leads and a red lead coming from it.
Look for the yellow lead with a gray stripe. There should also be a gray wire connected there....this would be the signal wire to the tach. If the rectifier goes bad, the tach will likely stop working. Check the rectifier out and see if it's still good and check for lose connections on the terminal strip.
00powerstrokin
is there a way to check the rectifier
00powerstrokin
i forgot to mention that when the tach does work it only reads 3000-3400 rpms. but the motor sounds like it is wide open
00powerstrokin
[whisper uid=81183]
how do i check the rectifier
[/whisper]
G DANE
If you rectifier is working, charging system will put out DC current. Connect a multimeter to the output and see what you have. If rectifier is shot, you can either replace it with original or use a Radio Shack cheap replacement.
00powerstrokin
my gauge on the console shows that it is charging so i guess it is good
00powerstrokin
[whisper uid=5277]
Enter private whisper here
[/whisper] the red wire was loose. but the grey was tight. i will get it out and put the dog ears on it tomorrow to see if it works now. what are the chances of the tach being bad?
