ThndrSki
Thread starter- Joined
- May 27, 2011
- 71
Hello, I was wondering if someone could possible help me diagnose some potentially bad news. Today I took my boat with a 1995 5.7L 350 Mag Alpha Mercruiser to the Gulf to run it around after using it the entire Memorial Day weekend, running approximately 45 gals of gas through it.
This weekend, launched the boat, tried to start it and it acted flooded. Finally got it started and it was running rough, missing, stumbling, etc. I briefly tried to idle away and gave it some throttle in neutral to about 2500 RPM thinking I might have fouled the plugs and when I went to go again, the engine died. Upon trying to restart, the engine was hydro-locked I found later on just the starboard side. Removed all 8 plugs, sprayed penetrating spray in each of the "wet" holes, and was able to get it started with the same results.... Stumbling, missing, etc.
The starboard manifold was hotter to the touch, and I could notice some steam coming from the starboard thru-hull exhaust. I also noticed the temp gauge (while running on the hose) go from 150-100 instantly at one point, and come back in about 20 seconds to 150 but could not repeat it. If you gave it full throttle in neutral, it would just sputter and stumble basically at idle.
The oil on the dipstick is clean and pure - but I had the engine started a few hours later and flushed it on the hose running rough.
I replaced all my manifolds last season with Mercruiser OEM, and I live in Tampa, so no freezing. Like I said, this boat worked PERFECTLY all weekend 1 week ago!
