1995 50 Hp. Evinrude Timing Specs??
PhrozeN_FisH
I am trying to set the timing on this motor and need the specs. If anyone can help me out it would be greatly appreciated.
Thanks
Silvertip
Honorary Supreme Mariner
Re: 1995 50 Hp. Evinrude Timing Specs??
If you don't have the specs, that says you also don't have a service manual which also means you are likely to do this wrong. I don't mean to be a smart ***** but messing with timing on a two-stroke requires that you know what you are doing. Idle timing and wide open throttle timing are critical and part of the link&sync procedure. You need to do the entire procedure which in my service manual is about 6 or 8 pages long. If you don't have a service manual, try your local library.
PhrozeN_FisH
Thanks for the advice Silvertip, but I've been working on these things for 25+ years and just left my manual at work.. Just needed the specs... You were not being a smart **** since you would be right for most people..
