1995 7.4L 300 HP manifold/riser?
Shaun78
When I replace them it looks like I need 3 pieces. manifolds, risers, seperate riser spacer. Is this correct? (2 gaskets also-top & bottom of riser spacer) Why don't they put spacer & riser in 1 like the newer ones. Add'l part=more money
Re: 1995 7.4L 300 HP manifold/riser?
Ayuh,........
When your motor sits so deep in the bilge that you need More rise,.....
The spacers are used,... I believe they come in 3",+ 6" versions......
What Newer 1s are you talking about,.......
The Aftermarket is Vast for those motors,+ drives...........
Shaun78
Yeah it just stinks, with that methos it's an extra 300.00 to spend on spacers. manifolds/risers are enough $$$$$
B O A T- Bring Out Another Thousand
Don S
How many 95 boats do you have? This one with a 7.4, and in your other post you have a 350 MPI.
What do you have really?
Shaun78
these are both boats that I am looking to buy. Buying only one but these are 2 that I have in mind.
180shabah
Check out GLM for your manifolds, risers and elbows. They are much cheaper than OEM.
Shaun78
thanks, are aftermarkets just as good? I want the new ceramic coated risera/manifolds. I hear they are much better
